One side of a dual gang socket in my garage has stopped working, after buying a replacement I can see that the old socket has two terminals each for live, earth and neutral, however the new socket only has a single trio. Is it safe to connect both wires into the same terminal, or is this more complex than a DIYer like me should be handling?
Edited to add, this video seems to suggest it's okay, but I don't know exactly how much I don't know.
Here is the new socket
Just to clarify, this is not about whether the wires will fit into the new socket, I'm pretty sure they will, it's whether I'm going to set something on fire if they're in the same terminal.
