Photo of the carpet, pad, and wood taken from lifting up the carpet from the vent cover.
Photo of an unfinished closet that leads to the crawlspace.
Photo 1: Photo of the carpet, pad, and wood taken from lifting up the carpet from the vent cover.
Photo 2: Photo of an unfinished closet that leads to the crawlspace.
Would a vent ever be installed on top of hardwood or is this definitely subfloor?
  • That looks likes plywood, which is usually used as sub floor. Plywood is basically thin wood glue on a base and can be a hardwood. Hardwood floors are usually about 3/4 inch thick real wood, usually in thin(4 or 6 inch) strips. Not saying that a bit of sanding, some stain and a clear cover coat it will look almost like a hardwood floor. Plywood is usually in 4x8 sheets.
    Commented Jul 30, 2023 at 21:19
That’s plywood subfloor. Definitely not hardwood.
Source: experience.
  • Rotary veneer grain patterns are something of a dead giveaway that falls under "experience."
    Commented Jul 30, 2023 at 21:27
  • Also the surface splinters and the fact that it’s a huge sheet at least a couple feed in each direction, not limited to a couple inches in width.
    – nobody
    Commented Jul 30, 2023 at 22:19
That is clearly plywood subfloor.
See the big nails they used to nail it on.
You would not do that with hardwood floor.
