Panels for bigger homes or homes with higher electrical loads are described as 320/400A. Why the "dual" designation? Which one is it, 320 or 400A that they support?
Structures and RVs follow NEC (National Electrical Code).
Utilities follow NESC (National Electrical Safety Code).
In the structure/NEC way of thinking, continuous loads put excessive strain on the system, and require a 125% disfavorable derate which is then included in the rating. For instance a 3800W water heater derates to 125% of that or 4750W, which is just under the 4800W of a 240V/20A circuit. So we treat that in all respects as a 20A water heater even though it's really 16A.
So in NEC, a load which is 80A continuous yet 100A intermittent is given the nomenclature of a "100A load".
In the utility/NESC way of thinking, you spec the continuous rating of the thing, and are tolerant of a 125% intermittent overload. So in their nomenclature, that same 80A continuous/100A intermittent is deemed an 80A load and they're fine with that having a 100A breaker.
So it's a difference in nomenclature and nothing more.
  • And that is fine. However when I go buy a 200A panel everybody calls it 200A panel, not 160 (200)A. That is why I had confusion Jul 27, 2023 at 17:58
  • @AlessioSangeli Yeah, there aren't a lot of retail shops who sell utility type gear. They'd only have one customer :) Jul 27, 2023 at 18:14
320 amp continuous
80% of 400 = 320.
https://forums.mikeholt.com/threads/320amp-vs-400amp.127202/
