Ripped out a deck to install a patio. The deck was attached directly to the rim joist(idk?) And now it's exposed. Do I need to put anything over it or can I simply install a replacement piece of siding? Thank you all in advance exposed rim joist and mudsill
    What you are calling a rim joist is probably a ledger. If you removed a rim joist, you'd be in a heap of doo. I suspect you can build out the existing gap with sheathing and insulation to match the depth of existing wall, and then align new siding lap, paint it, and call it good.
    – AdamO
    Commented Jul 27, 2023 at 17:43
  • When I add this additional wood to bump out in line with the rest, should I put any wrap on it or tape the seam? Commented Aug 2, 2023 at 0:04
