Thoughts on what may have caused this? Not sure how long it’s been a issue. Noticed the moisture under the ledge today that led to the discovery of what’s in the picture…. advice on what to do next? In South Carolina
  • Looks like water damage and mold Commented Jul 27, 2023 at 0:50
It's water damage, but the source isn't clear. Could be:
  • A leak at the window frame
  • A leak at the head of the window or higher up the wall
  • A leak at the window sash
  • Condensation on the inside
You'll want to track that down with some observation. The fix is basic drywall work:
  • Scrape away the loose material. Try not to damage the metal corner bead, if present.
  • Use a setting type joint compound for best future moisture resistance (as opposed to premix) to fill and skim.
  • Sand, prime, paint.
I don't worry much about mold. Unless you're overly sensitive or there's a huge amount of it, that's just life. Mold is already everywhere.
