My rental property has a void in the CMU/slab foundation that is leading to a water intrusion issue. I need advice on how to effectively force hydaraulic cement into a small hole to fill the voids. I was thinking some sort of large syringe type device, but can't find anything that could be used for this application.
  • Pictures? How big is the hole/void?
    – matt.
    Jul 23, 2023 at 22:05
  • Hydraulic cement usually holds better if the hole/crack is bigger on the inside, a reverse V. If the hole is bigger inside, maybe a pasty/piping/frosting bag might work.
    Jul 23, 2023 at 22:12
Large syringe? try a mechanic's syringe. eg: aliexpress.com/item/1005005682864385.html cement/grout is probably going to ruin the inside surface
If you need higher pressure (or want ot save money) spoon cement/grout into an empty caulk tube (use a metal rod to force the piston out the back) and use a caulk gun to pressurise it.
