Replacing a toilet flange. Is there enough of the fitting remaining to cleanup and use or do I need to do a full replacement?
    Will depend on how lucky you feel. The piece is on the floor, so cleaning and gluing is possible, but it will be under the floor and out of sight. It is low pressure, so it is possible, high pressure supply no way. For a good nights sleep, I would replace.
    Commented Jul 22, 2023 at 21:38
  • Usually a toilet is a single point connection to the main drain. The second connection might be concerning to a plumber, but I am not up to plumbing codes.
    Commented Jul 22, 2023 at 21:56
  • Also make sure your new flange is securely attached to the top of the new floor, since this doesn't look like it has support underneath it.
    – Armand
    Commented Jul 23, 2023 at 5:38
