I built & installed a new exterior door, including a new sweep. The threshold has wide aluminum "screws" for adjusting to the door sweep, however these appear to be frozen in place, all the way down. I tried using my drill clutch (all the way up to 10) and these won't budge. I switched to drill mode, and the bit broke. I have soaked the area in mineral oil but that hasn't seemed to help. Since they are aluminum, they are going to be relatively soft, so I'm hesitant to use something like an impact driver, but that's probably my next move. I thought these adjusters were simply screwed into wood or plastic, not more aluminum. Suggestions? TIA
    This sounds dumb, but have you tried turning them the other way? I have a sneaking suspicion that I've met backwards ones in the past. Jul 18, 2023 at 0:31
    What brand? Are you sure they're adjustable? Believe it or not I've seen those that appeared to be but weren't. That was disappointing.
    Jul 19, 2023 at 18:34
    And yes, they can be counter-intuitive. Running them in usually lowers the threshold, if I recall correctly.
    Jul 19, 2023 at 18:36
    If the drill bit broke, they are probably not aluminum, or a very cheap bit.
    Jul 19, 2023 at 18:38
    Mineral oil is not usually a penetrating oil of choice. Try something that's designed as a penetrating oil like PB Blaster™ or Kroil™. These are designed to seep into the fine gaps in thread and to chemically break down the mechanical bonds of corrosion that have formed. Also, try reversing as suggested above.
    Jul 20, 2023 at 13:43
Get a good driver bit. I can't remember the last time I broke one, but a hammer and a cheater bar were involved. Use an impact driver in both directions.
  • Impact driver got the stuck ones going. All set! I got the Craftsman CMMT14014, and the supposedly CV "Flat 8" bit actually bent/twisted a little, but thankfully didn't snap.
    – pwrgreg007
    Jul 30, 2023 at 18:22
