I’ve had the glass installers come by to fix, but I’m wondering if there’s any reason I should not fully silicone caulk around the brackets that hold the glass in place. The company has only caulked around the base of the inside where the glass meets the stone, but not the tops or sides of the brackets. The leak looks to only come from the brackets. It seems to me the water is dripping down the glass and through the top of the uncaulked bracket. Also is there any reason not to silicone the outside where the glass meets the stone.
Thanks!
