I got a natural gas BBQ with a non-threaded connection at the hose. There is also a gas stub-out under my deck that has a valve that can be shifted back. Both are non-threaded and they don't mate.
- Are natural gas BBQ hoses/connectors standardized and is the BBQ connector in the picture a standard one?
- Are these stub-outs designed to attach/detach the BBQ when needed? (I do not want the BBQ installed/connected permanently). In such case, are connections established by threads or other mechanism (e.g. shifting back a valve and plugging in)?
- Do these connectors have safety features that turn off when gas escapes too fast (i.e., when there is a leak or the BBQ is disconnected without closing valves)? I think propane BBQ have these.
- What is the valve of the current stub out exactly?
- How do I need to modify the stub-out to be able to plug in outdoor BBQs? (Note: I do not just want to fit it to the current one, the connection should be flexible for any BBQ I might purchase in the future)
Note: I know a shutoff valve will be required (and desired!) as well; I assume first is the shutoff valve and then the connector.
