I cracked some window trim in my condo. Where can I get a replacement? It looks like PVC material but I'm not able to find anything at Home Depot. Is this because its commercial material or something?
OK I ended up just ripping it off.
Clips into the side of the window
clips into the side of the window
  • We try to stay away from doing shopping. You know what you need, shop til you drop.
    – JACK
    Commented Jul 10, 2023 at 18:54
  • Can you take the broken piece out and post a picture of shape? Right now it just looks to be a flat piece that snaps into grooves, about the same as window blinds. The colour should be the hardest to match if so.
    Commented Jul 10, 2023 at 18:58
  • The new picture looks like a custom moulding from the window maker. The condo building department/maintenance should have information for the window maker or the trim maker in their records to get replacements.
    Commented Jul 10, 2023 at 19:55
