I have installed a door (not typical, somewhat makeshift for a theater window).
Closed Closed
Open Open
Open-Alt Open-Alt
I'm using wide throw hinges due to the clearances I will need.
The problem is that the bottom hinge closes fully before the other two hinges, preventing it from fully closing (and not bouncing back a little).
Bottom hinge closed:
Bottom
Middle hinge closed:
Middle
Top hinge closed:
Top
What would cause this?
    Please Edit your question and add a few pics to show us what you're dealing with.
    – brhans
    Jul 7 at 21:49
    @brhans Updated. I didn't have all the pictures available at the time of original posting.
    – Kevinicus
    Jul 9 at 19:52
  • If you don't want to redo the whole thing with more careful measurements, my suggestion -- I'm not a carpenter but I'm good at geometry, take it for what it's worth -- would be to loosen all the screws in the bottom hinge, and see if that's enough to let the door close fully. If so, then try to mark the position that the hinge comes to rest on the door and the jamb, and then see if you can adjust it to stay there. Jul 10 at 20:14
"Installing a door" is called hanging a door, and it's an advanced carpentry skill. So much that pretty much all doors installed today are of the pre hung type. Your problem can be caused by many things, but the root cause is that the hinges are not parallel, plumb, and on the same plane. Remove the door and make sure the door frame is square, plumb, and on the same plane as the wall. Then make sure both hinges are at the same depth on the frame.
  • The door doesn't have a "frame" perse. It's not typical (pictures added). I believe there are small variations on some of the measurements on the hinges though. Very small. 1/8" depending on how you squint.
    – Kevinicus
    Jul 9 at 19:55
Small variations can add up. You have to be precise to hang your own door. Or use adjustable hinges. There is a reason why they are popular.
I would remove one hinge temporarily (perhaps the middle one). It will allow you to see if this is the problem. And then redo it to suit. Shift the hinge vertically by 5mm.
