10'x16' insulated off grid "cabin" build. I want to use gable vents for my ventilation because it seems way simpler than a ride beam and soffit vents. I have a post centered on each 10" wall to support the ridge board.
- how would I install a centered gable vent around this post?
- what other framing do I need in these triangles on the gable ends above the top wall plate?
- if I want a foot overhang can I accomplish that by just overhanging my sheathing on the gable end or do I need to build a "ladder"?
I have my walls framed and stood up with some bracing. I am stuck overthinking and over researching roof venting, soffits, rafters, etc.
