I’m trying to hang shelves but the wall that I am hanging them on is technically an exterior wall.
I live in a Florida home build in 1981. I’m assuming that they used concrete block filled in with cement about 3/4 of the way up the house and then line the inside of the wall with drywall then painted.
I tried to pre-drill a hole with my Kobalt 24V Hammer Drill with a Tapcon 5/32 drill bit. The bit goes through the drywall and hit the concrete but will NOT go any further. I have the drill in hammer mode, on the 2-speed gear option and on the 24 “position clutch”. (Basically the same as a video I watched showing how to use this drill). But nothing is going through.
