I have a Danby Designer mini fridge (‎FBA_DCR032A2BDD) that stopped cooling recently. This fridge was only been manufactured in 2019 so it feels like a waste to throw it out without at least attempting to fix it.
I did some research and found that it might be the PTC & OLP Combination 2.6SM4R relay that needs to be replaced. I have some experience with repairs so I thought I would give it a shot.
When I was able to look at the fridge, it was still plugged in, so I unplugged it. What concerns me is that the compressor was very warm to the touch despite the fridge no longer cooling.
Question
Is it possible for the compressor to warm up if the relay is broken, or could this indicate the fault is elsewhere?
I included the electrical diagram if this would shed some light on someone more familiar with fridge repair:
Additional Info
  • The back of the fridge seems to only have the power cable, the relay and housing, and the compressor. I do not see any kind of fan or coils. I included a picture of the back on the white version of this mini fridge if it helps.
    there are numerous failure modes where the compressor would run but the unit not cool.
    – Tiger Guy
    Jun 28 at 12:54
  • Grab your multimeter and see if you're getting voltages at appropriate locations when it's supposed to be running. You might have a broken wire, a short, a loose connection, who knows...
    Jun 28 at 13:02
If it is a bad start relay as you suspect, the motor could be quite warm from failing to start but having current running through it.
However, it could also be a refrigerant leak causing the fridge to run but not cool, and this sort of fridge is not made to be economically sensible to do refrigeration circuit work on - the valves are not there, it's only intended to work until it doesn't and be discarded, because getting it repaired will cost more than replacing it with a new cheaply built fridge like it.
