I recently went out of town for 10 days so I decided to turn off water to the house. Not from the main because I want sprinklers to run, just the water that goes in the house. I also tried my best to drain the water as much as I could before I left for my flight.
When I came back, I turned on the water. When I flushed I noticed a weird banging sound coming from the WC. It may be the air bubbles trapped in the pipe. The sound came from every toilet (3). The sound was gone after couple of flushes. How can I prevent trapping air bubbles or releasing them gently so I can safely flush or use the faucets without hearing those air sounds.
- After I flushed each toilet, the sound does not come anymore but I am asking for future references.
- There is nothing wrong with my water line, I just turn it off and try to drain the pipes when I go on extended periods of time.
