I am removing cabinets mounted on my garage to put in storage and then move to an undeveloped property. The cabinets are multi-door, wall mounted 1/2 and in. fiberboard. All of them are built with one 4" wide horizontal fiberboard wall-mounting member across the inside top. To add to the stress of the task, I want to move them (as opposed to land-filling them) because they were built by my late father.
I had to take some of them off the wall to make room for grid-tied batteries in the garage and have already discovered I need to immediately address the racking issue. I am without help, so it is going to be furniture dollies and hand-trucks and their inherent "off-bore" vectors of force.
And that brings me to my question: what are the minimum things I can do to address the racking, preferably something hidden inside the carcass, like corner braces, if permanent; or, something temporary, but effective, such as strap-type clamps or a diagonal strip of wood(?).
I will happily accept any and all suggestions.
  • Are you sure they are made with fibreboard? My understanding of fibreboard is a board more for insulation/sound reduction than structural. Maybe you mean MDF or OSB?
    Jun 23, 2023 at 22:15
  • If you place them on the hand truck with the back against the truck's upright, there should be minimal racking.
    – Huesmann
    Jun 24, 2023 at 13:38
I assume from the fact that you have a racking issue that they lack a back other than the mounting strip.
I'd attach a 1/8" plywood (whatever flavor you can get at most reasonable cost - luan, floor underlayment birch, etc..) back to them, which functions as a whole lot of X braces when it's fastened to the case all around. Or if plywood pricing is absurd but hardboard (Masonite®) isn't, that will work, too.
I understand. Being they were made by your father, save them at all cost.
would add a simple "L" bracket at least 2 inch at all 4 inside corners. Leaving them there when the cabinets are hung at the new location.
Good Luck
