We recently moved into a new residence with a tub that would drain very slowly, to a point where a regular shower resulted in nearly knee-high water that took ~30 minutes to make its way down the pipes. Applied all the usual troubleshooting - removed the lever drain plug, tried the baking soda & hot water method, snaked the drain as much as we could, used copious amounts of dish soap and plunged it vigorously with the overflow covered to no effect.
Finally we decided to get out our wet/dry vacuum, stick the hose on top of the drain with the cover removed, plug the tub overflow and run the unit in suction mode.
The result was instant - we pulled up nearly half a vacuum container's worth of black sludge, hair, gunk and other nastiness out of the pipes, and after ~5 minutes the tub was draining again perfectly. I was left wondering why this isn't the go-to solution for persistent clogs before the "call a plumber" step.
My question is, can I safely use this method on other blockage-related slow drains around the house (like sinks)? Does it depend on the material of the pipes used for a particular section? Would doing so be likely to damage any seals? It seems too convenient of an approach to forego, but I don't want to cause any long-term damage either (and I'm a bit surprised it's not frequently advertised as something to try). Thanks in advance!
