So I just had nice new James Hardie siding put on. They tore off everything, replaced the insulation from the outside, put on new sheathing, house wrap, and then Hardie board.
Part of the contract was to remove the gable vents (they are also a roofing company, and suggested I just have the soffit and ridge vents).
I discovered the below in the attic today - they put up new sheathing where the gable vent was (that's new OSB there), cut a freaking hole in it for a gable vent, and then slapped house wrap over it before putting the siding on.
They only did this at one end of the house - I'm assuming it was accidental, e.g. someone not realizing they were supposed to remove the gable vents.
How much of a pain in the ass should I be about this? Should I just cut some OSB to fit that area, nail or screw it in with 2x4s and cover with seam tape?
Or should I demand they come out here, pull all the siding off that area, and redo it all? I'm nervous about it because it seems to me that I am one tear in that house wrap away from water getting into my attic.
