I’m surprised this wasn’t easier to find by 2023, so I’ll ask here to hopefully put a good answer on record.
I’m remodeling a small, two parallel wall, galley style kitchen. With respect to under cabinet (wall cabinets only) what electrical should I rough in?
We do not have the lights yet, but assuming a dimmable hard wired LED of some type under each of the four wall cabinets (two on each wall).
Considering advice to only run one cable per fixture location, I was going to place a box w/cover behind the refrigerator for those two cabinets, then, a box w/cover under the sink cabinet to catch those two wall cabinets.
Should I run 14-2 for 120v to each light location or plan to only run low voltage (12v or 24v) to each location?
If all four locations are being controlled by one in wall dimmer, I’m assuming I would only have one transformer. The standard 14-2 120v to each light location doesn’t seem correct to me?
