All of my ceiling fixtures have porclean sockets which are deep and incandescent bulbs have a longer thread base to make contact at the bottom of the deep socket. More than half the ceiling fixtures (with 2 to 6 sockets each) in my home will not work with led bulbs because the base threads are shorter in length and can not screw deeply enough into the socket to make the bottom connection.
Is there anything I can add to extend the led bulb thread base by approximately 1/16th or 1/8th of an inch; or screw something into the bottom of the porclean socket to raise the height of the connection point on the bottom to make contact with the led bulb?
