I need to move a 50A generator breaker in my service panel from one side to the other to match the configuration of the interlock switch. I will need another 12" of cable to move it where it needs to go. Replacing the #6 cable all the way back to the generator outlet is expensive and time-consuming, so I plan to splice the additional length. I have 3 solutions I know of that would pass inspection (although I don't plan on pulling a permit for this job, I want to follow best practices).
- A. Wire nuts
- B. Split-bolts, taped with electrical tape
- C. Large solderless connectors
Thanks for any insight.
