My question is whether I should completely cut out and replace a PEX B copper crimp connection to a barbed 1/4 shut off valve (for toilet water supply). I didn’t have a lot of pipe length to work with and I got the crimp ring on two of the barbs but not the first one. I pressure tested, and everything is working fine so I would rather leave it, unless I am taking an enormous risk.
1 Answer
It's not just the ring, the valve isn't pushed home in the pipe. And this is a toilet, where the valve does get some use whenever the flapper gets gunked up or the chain gets tangled up or whatever. And there isn't a copper stubout so I'm guessing that bit of pex is just crimped loosely onto an L or a T and flapping around inside the wall. So operation of the valve is going to stress your poor crimp more than usual.
If it was just one of those things I wouldn't have a strong opinion. But you should cut open the wall, install a copper stubout, firmly fixed to a block, cut the new stubout to the right length, and use a compression or sharkbite valve that can easily be replaced in 20 years when it fails. And a pretty escutcheon. Ya, it's some drywall work too.
