I have a length of 1/2" ADS Polyflex tube that I'd like to connect to a hose bib. What adapters do I need to get this job done?
This is the tube https://www.homedepot.com/p/Advanced-Drainage-Systems-1-2-in-x-100-ft-IPS-125-psi-NSF-Poly-Pipe-X2-50125100/205903467
My preferred hose bib is the Sharkbite Garden Valve for the simple reason that it comes with convenient screws for mounting to a post or the side of a raised bed. The Sharkbite website indicates that the product is "Compatible with PEX, copper, CPVC, PE-RT and SDR-9 HDPE pipe." Would that work with the ADS Polyflex tube which is labeled SIDR-15?
https://www.sharkbite.com/us/en/brass-push-to-connect/valves/outdoor-hose-valves/garden-valve
Other options I'm considering is finding some way to transition to something like a segment of PVC between the tubing and the hose bib or using a different bib and transitioning to NPT threaded adapters.
What do you all recommend?
