I had my roof replaced last year and I am now seeing consistent temperatures in the attic that exceed 40 degrees over the outside temperature. For example, it was 62°F the other day and I had 108.5°F in the attic (house is in the northeast).
The attic surface is 26x22. Previously I had 3 box vents and small intake vents at about 6 feet intervals around the soffit and did not have this problem. The contractor installed a continuous soffit and a CertainTeed filtered ridge vent instead of box vents - the ridge vent is about 6 feet in length.
The exhaust seems a bit lower than before, but intake seems a lot more (I see daylight all around from inside the attic, so I assume that is all intake) so I am a bit baffled. By researching the only explanation I can think of is that there is now too much intake now and the system is unbalanced, creating high pressure in the attic and venting out from the intake rather than the ridge, with much lower performance.
The ridge is indeed small (roof looks squashed because of perspective):
From inside the attic it measures 80 inches long and about 3 inches across. This is how the ridge looks from inside the attic:
And this is how soffit intake looks like (I removed the baffles to take the inside picture):
The ridge vent show daylight from the inside but I'd does look indeed a bit tight.
Does anyone have any insight? Should I install more exhaust? In this case, even if I installed box vents I would have to close the ridge vent not to mix exhaust types, right? Or close some of the intakes?
If I have 108 when it's 62 outside I am afraid of what is going to happen in the summer.
The total area of the attic is 572 sqft. It's a hip roof, so there is not much ridge, and the vent covers the whole ridge. I might have lowballed with 6 feet, but I'd say it's between 6 and 8 (the cut that I see inside the attic is 80 inches long)
