I have a Hampton Bay 5-blade ceiling fan with three candelabra lights. One of the lights flickers seemingly randomly whenever it is on. I replaced all the three candelabra lights with new LEDs and the problem persist. The flickering is not affected if I turn the fan on or increase fan speed. I am not sure if this is a problem with the circuit the fixture is connected to (unlikely), a problem with the fixture itself (cheap one so maybe?), a problem with the socket (given that it is the same one the flickers despite changing the bulb). I would appreciate any suggestions on how to troubleshoot and fix this flickering light. Thanks!
Light fixture: (https://www.homedepot.com/p/Hampton-Bay-Glendale-52-in-LED-Indoor-White-Ceiling-Fan-with-Light-Kit-AG524-WH/300937526).
