I have 14 zones which work fine except for zone 6. When it starts water starts coming out of backflow preventer. I already changed the valve parts and solenoid. Is there any thing else I can check?
3Traditional sprinkler designs have one back flo preventer regardless of number of stations. Sounds like a problem with the station valve.– blacksmith37Commented May 18, 2023 at 14:47
You could improve your question by providing more details on the sprinkler and a photo– Rohit GuptaCommented May 19, 2023 at 3:17
Add a comment
1 Answer
It sounds like you have a blockage in that zone and the water is dispersed through the backflow.
Try taking the heads off at the beginning of the zone. Also look for damp ground where a brake may have occurred. If you had a break and repaired it there may be debris in the pipe that has been compressed by the water and is now a solid block.
