How can I secure these hinges on the door frame? I need to secure them into the wood of the door. They've loosened over time and screwing them back in fastens it for a few weeks but there isn't enough tension between the screws and the door to hold it in place.
A quick fix would be to remove the screws and fill the holes with toothpicks and a quality wood glue. Once the glue dries, drill your pilot holes and screw the hinges back into the door.
A better fix would be to remove the screws and drill 3/8" or 7/16" holes into the door and glue in 1" long dowel pins. Then drill your pilot holes and screw the hinges back into the door.
  • 5
    Most hinge screws are short and small. Using longer and larger screws after repairing the holes will help also.
    May 13, 2023 at 23:35
  • And if you don't have any toothpicks handy, match sticks work too.
    – Simon B
    May 14, 2023 at 11:23
  • If you can even find wood matches anymore!
    – Huesmann
    May 14, 2023 at 12:12
  • I like to use the toothpick trick, too. Except I don't wait for the glue to dry, I drive the screws into the glue and toothpicks while it's still wet. Leave the door closed for a few hours after that to allow it to set. May 14, 2023 at 12:21
