I was thinking of surrounding my firepit with a hexagonal pergola, each side probably about 14' long, arranged like the the below image but wondered about the base. Each of the 6x6 posts would be connected by boards at the top (maybe 1x6 or 2x6) and I thought the shape itself would lend to pretty good stability. I was trying to think what would be best for the base though. The ground here is heavy clay so I was concerned about putting 6x6x12 posts 4' in the ground (Western NY) due to the poor drainage.
My other thought was putting in concrete footers and using 6x6x8 posts. Would that be a better option? I have not worked with concrete footers before though there seem to be vids out there using form tubes and it seems a simple process. Not sure how well the fasteners hold and would want to avoid any sway in the structure (the top connectors would just be post to adjacent post, no cross beams in the plan) Between posts I may eventually put in swings but at most probably hammocks. Any advice would be great!
