I'm redoing a shower drain. I can see this thing which looks like an iron flange, with an iron drain going into it? Is this thing that looks like a flange removable? Is the drain inside the flange removable?
I'm looking to rebuild my shower, and I believe these need weep holes so the water can drain from the mortar bed into the drain. I don't see weep holes here. Should I use this drain? Or should I remove it? If so, how do you remove it?
Top-down picture of drain Side profile of drain
  • what are you talking about weep holes so the water can drain in the mortar bed
    – Traveler
    May 6, 2023 at 20:20
  • @Ruskes typo "so the water can drain from the mortar bed into the drain" May 6, 2023 at 21:04
