I want to hang a 27 kg boxing bag from a ceiling beam in my garage, but I'm concerned about the safety of doing so. The garage was built in the 60s, and the wood in the structure is quite old. I'm not sure if it will be able to support the weight of the bag, especially when factoring in the swinging motion.
I have calculated that the bag and the swinging motion will require the beam to support around 200 kg. I have attached a picture of the location where I want to hang the bag and the support structure itself.
I am also considering creating a type of pulley with a climbing rope that hangs over where the two triangular beams meet where I hang the bag at the end of the rope, as it seems like the strongest point.
My question is, is it safe to hang a 27 kg boxing bag from this ceiling beam in my garage? How can I determine if the beam is strong enough to support the weight and motion of the bag? Are there any additional supports or reinforcements I should consider adding to ensure safety?
Any advice or insights would be greatly appreciated. Thank you in advance.
