I'd like to shorten a Hansgrohe Techniflex hose. The spot that the pipe nipple comes out of the wall is too low and the handshower can hit the tile.
Here's a pic. I already broke one hand shower this way.
hose too long
The Techniflex hose is a silver flexible hose that has been great, no kinks, flexible, no uneven surfaces to gunk up.
The fitting on the end is shown in the attached pics. It's clearly a brass piece that fits into the cut hose end, with a collar crimped to hold it in place. The od of the hose is a hair under 5/8 inch (I don't know the id). The crimped collar is 35/64 final dimension (aka 0.546 decimal inches).
Anyone recognize this setup? I think I can get the brass insert out by cutting the crimped collar, and I'm wondering whether a PEX crimper could secure it (after cutting the hose). Looks like it is a stainless steel ring.
I'm thinking maybe it is a "stainless steel press sleeve" like Viega or Apollo make? I guess this might be the 1/2 nominal size?
Techniflex crimped collar show crimped size
Techniflex crimper collar
Threaded end
Maybe this:
Apollo sleave crimped
  • 4
    A decent suction cup (or ceiling mount, depending what you've got) hook to hold the hose a bit higher seems much less likely to cause grief than attempting to re-crimp a hose where you probably can't source the correct crimp sleeve and crimper and are attempting to hack it with what you can get.
    Apr 21, 2023 at 16:37
    Those press fittings usually require special(expensive) equipment. If they are like hydraulic hose fittings, they require high pressure. Most pex fittings leave a bump/ridge and are not smooth for skin.
    Apr 21, 2023 at 17:54
    Very unwise to do such a thing, but I must admit I do not understand the problem you are have with this handheld shower. Apr 21, 2023 at 21:06
  • @JimStewart the hose is too long, so the handheld unit hits the floor if it's dropped. You know, things in the shower can get slippery.
    – Huesmann
    Apr 22, 2023 at 13:54
  • I don't drop mine, but if I would drop it, it would strike the rubber (now PVC) non-slip mat in the tub/shower I use. I wash our 25 lb dog in the tub and benefit from the length of the hose to wash the underside of the dog. But if the length bothers you, the best solution would be the stick-on hook proposed in the comment by @Ecnerwal. Apr 22, 2023 at 15:50
Thanks to all for the questions and comments.
All sorted!
Showing reinstalled handshower now not touching the floor.
I was able to do this with the Apollo 1/2 inch Stainless Steel sleeves ($8 for a 10 pack) and the matching crimper sold at Home Depot (~$60) e.g.:
https://www.homedepot.com/p/Apollo-1-2-in-Stainless-Steel-PEX-B-Crimp-Sleeve-10-Pack-PXSS1210PK/301921350
https://www.homedepot.com/p/Apollo-1-2-in-and-3-4-in-PEX-B-SS-Sleeve-Tool-69PTKH0014SS/301921148
I don't have confidence that this would hold under real pressure, but for a hand-shower the joint is never under real pressure. But, no sign of leaks, even with the higher pressure button setting on the hand shower.
Unnecessary details below
I bought an Amazon Warehouse version of the techniflex 63" to experiment and one fortuitously came with the hand-shower end entirely off. Otherwise it's a long, awkward process of hacksaw work that destroys the factory sleeve entirely.
The Apollo sleeve is quite a bit bigger than the factory one.
Apollo 1/2 uncrimped compared with factory sleeve crimped
The factory sleeve is much more like the Viega 3/8 stainless steel sleeve (~14.7mm), the od of the barbed insert is exactly the same as Viega 3/8, so I ordered some of those. But no way the 3/8 viega slips over the OD of the technifex tube (which is way thicker than pex-b), and in any case I could not find a reasonably priced crimper for 3/8 Viega pex crimping.
Uncrimped Viega 3/8 sleeve compared with crimped factory sleeve
FWIW, I also tried the copper rings in the 3/8 size but those also wouldn't slip over the end. I tried compressing the end in a few ways but that was hopeless. Eventually I decided just to try the stainless steel Apollo 1/2" sleeves.
I had to crimp in a few different places down the sleeve, including the flare at the hose end of the crimp, because the female threaded end (chrome) won't fit over that flare otherwise.
Apollo 1/2 primed sleeve with flare flattened
In the end the longer sleeve shows more than the factory one, and there is a little waviness from crimping the flare of the sleeve, but it doesn't look bad.
Showing crimp coming further down techniflex
  • Tragically this connection did not last, it fell off after a few weeks. I think I'll try to find someone with the Viega 3/8 crimper and see if that can work. Boo. Jul 25, 2023 at 15:34
  • the factory crimp looks more like propress jaw marks. icrimp makes a kit that comes with different heads for different size rings including 3/8. Feb 12 at 3:57
Instead of trying to re-crimp an end, remove as much as you want from the middle and reconnect the two pieces with a barbed connector.
They come in various materials and colors, and with or without a central flange as in this picture.
  • For what it's worth, this makes a ton of sense, but given that this particular hose is much thicker walled than regular pex, (od of 1/2, but id of 3/8 pex) you still have to deal with crimping it. I suppose you could use a cinch band (3/8" cinch definitely worked), but those don't give a great finished look. May 5, 2023 at 0:58
