When I trigger the valve through the irrigation controller, I get a small water trickle, then nothing. If I quarter turn the solenoid or use the bleed valve, I get a full flow of water. Here's my irrigation setup (see picture):
- Hunter Node 400
- 1" Hunter irrigation valve
- DC Solenoid
Other relevant information:
- I have a 2nd irrigation valve on the same manifold, with the same issue as the first one.
- I have an 3rd irrigation valve situated 60'/20m away and about 6'/2m higher that works fine.
- If I close the water line, open the valve with the controller, then re-open the main, the water flows.
How do I get this to work?
