I am located in Florida. I have an irrigation well and when I open the valve for the pipe that is on the top of the well, the water is under pressure.
Pump is mounted on the side and is a surface mounted jet pump. Well is probably less than 25 FT deep.
Why am I seeing water under pressure from the well?
    Where in Florida is the well? Commented Apr 8, 2023 at 15:02
11
An artesian well brings water up to the surface without pumping. This is because the water in the underground reservoir is under pressure because it has water in the water-bearing layer at a higher altitude, and is not able to escape before you drill down into the layer. These are encountered in many areas of the world.
    +1! You can self-delete your now duplicate comment on the OP. ;)
    Commented Apr 8, 2023 at 12:02
