I'm an owner-builder, getting ready for a close-in inspection which includes plugging and testing the DWV system for a new bathroom. I have a standard 3" test ball that I have used as a test plug in the past, but that was always with a standard sanitary tee. The plumber that I hired used a Y fitting for the cleanout, and the test ball won't work. If I plug the outlet to the Y, then the water will just come through the cleanout. And I can't plug the cleanout separately in this case, because of the chain attached to the test ball.
How do I plug up the DWV system for inspection, when the cleanout uses a standard ABS 45% Y hub?
Flexible double test plugs are what I've used in the past.
flexible double test plug
Could you pass the test ball into the branch of the wye valve-stem-end first, then work it up into the pipe above the wye inlet, and finally inflate the ball in that position?
Otherwise, if the pipes can move around a bit, perhaps cut the pipe and install the familiar sanitary tee above or below the wye.
