I installed a new Chamberlain B4505T garage door opener. When I press the open button the lights blink twice and nothing happens. The sensors seem to be installed correctly. There is an amber light in one and a green light in the other. If I block the beam the green light goes out. Does anyone have any idea of what could be wrong?
  • Is it the actual lights flashing and not the LED's next to the learn button?
    – JD74
    Apr 3, 2023 at 15:57
  • It is the main garage lights flashing. You can hear the relay click on and off. Apr 3, 2023 at 17:23
I figured out what it was. I didn't have the up and down limits set. Once I set them everything worked fine.
  • What do you mean by that? Were they not set by default?
    Apr 3, 2023 at 17:44
  • I don't think they can be set by default because the motor doesn't know what position the trolley is at. Apr 3, 2023 at 18:22
  • Every opener I've ever installed has had some existing start and stop position which just needed shifting. I don't recall every encountering a procedure that required setup before the thing would move. Maybe it's a recent thing.
    Apr 3, 2023 at 18:26
    It might be a safety feature to stop you from folding your door in half if the stop is set too low. Apr 3, 2023 at 19:07
  • Had the exact same issue and setting the limits was indeed the fix. Would be a useful addition to the manual's troubleshooting section. Thanks for posting. Apr 23, 2023 at 20:18
Two Flashes: A wire to a sensor is shorted out or a black/white wire is reversed.
https://support.chamberlaingroup.com/s/article/What-does-the-flashing-LED-next-to-the-learn-button-mean-1484145519298
https://www.google.com/search?q=Chamberlain+B4505T+two+blinks
That information is probably also in the installation manual. There's usually a troubleshooting section.
