New to plumbing here, I was trying to do a DIY and add an expansion tank to my water heater. I noticed it was dripping from the fitting, so I tried to take it off to apply more tapes and pipe dope, but when I took it off almost completely from the adapter, the water started to shoot out from the expansion tank like crazy. I was all wet through, and about 1 gallon of pressurized water shot out from the expansion tank.
I did pressurize the tank to 68psi, which is the same as my faucet. Is there something I missed? I did forget to turn off the main water valve or the cold water valve. Could it be the only reason that the expansion tank shot out water to half the room?
Any advice is appreciated.
