I have a Grohe pressure balanced shower mixer (cartridge is model 47157000) and the check valve (model 47158000) on the cold side isn’t working.
When the check valve is installed, hardly any water comes out. When removed, the shower is great.
Knowing that the hot water is supplied by (edit) a dedicated on-demand water heater, what is the downside of removing the check valve?
My primitive notion is that the pressure on the hot side is roughly equal to the pressure on the cold side, so it seems like there shouldn’t be a problem. But I’m the first to say that I’m not a plumber, so that’s why I’m here.
