I have installed the 10 breakers transfer switch, so if the power is out I can just connect the generator to the inlet box. I dont want to disturb my neighbors at night so I am planning to install battery backup.
I did research and came up with the following setup: use 3000w 24v sungold power all in one converter, it has 3 modes(Utility, solar and battery), plug 110v outlet in my garage to the inverter input and plug inverter output to the inlet box and of course plug the battery to the inverter. I am planning to add solar panels later.
My understanding is, if I use the Utility mode, the power from that 110v outlet in my garage will go through the inverter and feed all the 10 breakers on my transfer switch.
Is this setup safe? Or Am I misunderstanding? Thanks!
