I am making a drive in a lot with some low spots. I am curious if anyone has insight or experience using trees cut from a lot as fill for a driveway, to make a level drive.
The lot is all relatively flat bedrock, with some ledge cavities a couple feet deep, that is where the logs might be used to as fill, thinking perhaps they can can rot, but won't be able to sink into the earth or wash away.
Thanks for any thoughts!
