I have an AEG KM8403101m Micromat combi oven. During cleaning last week the door switch got locked in the closed position (even though the door wasn’t closed at the time).
The microwave now shorts out as soon as it is switched on.
I assume this is a safety feature (though I may be wrong).
Is there a way to reset to door catch? It seems pretty much locked in position and no amount of prodding through the small hole at the front will get it to move.
The door has two insulting hoop like protrusions that go in the pictured hole. I think the mechanism inside to door swings the catches down when it shuts to lock the door in place.
