I have a broken silcock with no identifying marks on the valve body.
Here is a picture of the internals, with the boot w/ sealing surface separated from the rod that pushes it against the valve seat:
I'm having no luck finding a replacement. Any help identifying would be much appreciated! Thank you in advance!
