I have a frameless shower door that has a gap strip coming off. It's a clear strip which probably came with an adhesive backing. The strip is 1/4 wide by 1/8. Can anyone help me identify this part so I can purchase it? I'm not sure if this a silicone tape. If so I can't find 1/4 which is about 6mm.
  • A profile shot would be helpful.
    – JACK
    Mar 17 at 16:30
It will be near impossible to identify it from the picture you provided. Your best bet would be to get some rubber contact cement or epoxy and apply it to both surfaces, following directions, after thoroughly cleaning both surfaces. The contact cement will set immediately whereas the expoy should be taped untill it's hardened.
You could also snip a piece off the bottom and go hunting on the internet or around local home or plumbing fixture stores for a replacement.
