In about a week I’ll be closing on a new house and am looking to remove this short distance of wall between the kitchen and living room. Based on the direction of the roofline, I’m pretty sure it’s a supporting wall, which means I’ll need to put in an LVL beam. A few questions I’m hoping someone here can help with:
  1. Will I need to run it the entire length of the wall (e.g. dig into above the current doors)?
  2. What type of wood should I purchase to support the LVL beam on either side?
  3. Can you recommend a good online calculator to figure out the dimensions of the LVL beam I need to buy, or tell me the dimensions?
Additional information:
  1. It’s a single floor space, so no extra weight above it other than rafters and roof
  2. Snow: the house is near Cleveland Ohio, so in the winter we get (on average) up to a foot of snow at a time.
picture of wall coming out
Picture of wall coming out
Dimensions from inspector. Dividing wall isn't pictured, but is between kitchen/dining and living room:
Floorplan
Floorplan
  • Welcome. Please take the tour to learn how to use this site.
    Mar 15 at 19:07
  • Do you have a basement under the house? The space marked basement seems to be odd(maybe a typo?) If you do have a basement, is there any beams under that wall?
    Mar 15 at 19:22
  • The section I'm removing the wall from is a ranch, the other 1/2 is a split level.
    – Alex
    Mar 15 at 19:47
  • "Based on the direction of the roofline" — which direction does the peak run?
    – Huesmann
    Mar 16 at 13:26
  • It is opposite the direction of the wall which means joists are perpendicular to it
    – Alex
    Mar 21 at 19:51
Depends. What are the existing headers bearing on? What will you bear new trimmer studs for the new beam on? If you can run new trimmer studs down to the subfloor and block underneath to something capable of bearing the load, you can use a separate beam.
Standard SPF studs are fine. There really is nothing else commonly available. The span may call for them to be doubled.
Talk to your lumber yard. They have people on staff trained to do this. Even with a couple decades of homebuilding experience I don't trust a simple calculator to cover all the nuances of a situation.
Also note that this kind of thing typically requires that you pull a permit and facilitate inspections. Therefore, present your proposal to the inspection office before starting, to reveal any concerns they may have before you have to tear it apart and redo it.
Also also note that you need to properly support the framing above while you do this work. That's often done with a temporary wall on one or both sides, but it depends on the actual framing scenario. Be safe.
    Thanks. I was asking about type of wood for supporting the lvl beam because I didn't know if it required a special kind of support since it'd be holding more weight, or if normal framing lumber (e.g. 2x4's) was enough.
    – Alex
    Mar 15 at 19:04
    In my case they used another form of manufactured lumber, specifically designed for lengthwise compression. I don't remember what it was called. They also had to install a steel C-beam in the basement to carry the newly concentrated force to main beam and foundation. This is why one hires an engineer to design it properly.
    – keshlam
    Mar 15 at 21:32
