BACKGROUND: 1942 brick home with crawlspace. Bathroom was added sometime between 1950-1970. The crack has been there for at least 20 years (likely more), and I'm guessing it was caused by insufficient support underneath. (I've seen other evidence of shoddy workmanship with this section of the home.)
I'll be selling the home in the next 2-3 years. I don't want to re-tile because there's a decent chance this bathroom will be demo'd to make room for another wing by the next owner. But I'd like to at least fill in the crack and/or try and make it look more presentable.
Should I just use a clear epoxy to fill it in, or are there other options? (And can I do the same for that grout gap on the right wall in the second pic?)
