I am replacing the AC condenser motor , the original had 3 wires, black, purple and brown, in the dual capacitor the brown is to the fan and purple to the common.
My replacement motor has 2 black and 1 brown and 1 brown with white. I am kind of confused if i connect one black to common or leave one black and brown with white alone. Any input is appreciated in the capacitor, thanks enter image description here
  • Depending where you live the wire color would have different meaning.
    – asinine
    Mar 4 at 3:34
    check the label on each of the motors for a connection diagram
    – jsotola
    Mar 4 at 3:35
  • I uploaded an image of wiring to new motor
    – Nomad1z
    Mar 4 at 19:09
The wiring diagram on the motor pictured calls for a capacitor (7.5 µF and 370 VAC rated) between brown and brown/white.
Line goes to black (so line 1 and line 2 if 240V, or line and neutral if 120V) with both blacks being used to connect to the line in either case.
  • So both black wires from the motor will connect to black line wire from contactor or both black wires are going straight to contactor. The reason I ask is the contactor is on one side of the unit and a wire was ran as an extension to the side where the motor wires extended from motor wire tube near dual capacitor. I hope it make sense
    – Nomad1z
    Mar 4 at 20:21
  • Your hope is not borne out by the lack of a picture of that, so that we can see what you see. They do not both connect to the SAME wire - they connect to both sides of the line supply, whether that be two hots (240V) or hot and neutral (120V) one motor black to each side of the line.
    Mar 4 at 20:30
  • I’ll try to provide some pictures soon, thank you for the feedback and patience, I appreciate it.
    – Nomad1z
    Mar 4 at 21:31
  • Uploaded a picture with wiring info
    – Nomad1z
    Mar 11 at 15:29
  • Update, I ordered an OEM replacement motor and everything is all good.
    – Nomad1z
    Mar 18 at 16:19
