In my area, the ptrap arm length (section between waste stack and ptrap) is limited to one foot per 1/4” of the pipe’s inner diameter. (at a 1/4” per foot slope)
I want to move my washer a bit further away from the waste stack than that (8feet overall), and i can’t enlarge the pipes (because the waste stack is common property in my building — what i own is the 2" threaded insert into it, and everything “upstream” from that).
Could i leave my current ptrap in place and extend the standpipe side of the setup instead? Or do a combination of both— i.e move the ptrap, and then “nudge” the standpipe further?
example drain setup
    How far do you intend to move the washer from the standpipe? That dimension will give us a better idea of what you are trying to accomplish. Maybe just a longer hose?
    – RMDman
    Commented Mar 3, 2023 at 13:45
  • about 8 feet away.
    – init_js
    Commented Mar 4, 2023 at 10:36
  • leaving the drain in place, and extending the washer drain hose would be going beyond manufacturer recommendations (1.5m max). would the flexible extension have to run waist-high along the wall on a slope to avoid trapping water?
    – init_js
    Commented Mar 4, 2023 at 10:45
