tl;dr - I'm trying to find out the name for the metal connectors in the first picture...
I've been trying to troubleshoot a faulty Hive (UK) heating controller and got to the point where I've opened up the box connected to my combi boiler to see if there were any obvious problems inside.
It looks like there's some broken electrical connectors on the back plate of the unit (or maybe my I've done myself a mischief and broken them while tinkering) - but in any case some of the connectors appear to have one of the "fork" pins missing, for example the connecter numbers #3 in the image below:
Can anyone help with the name of these type of connectors? I've tried various combinations of "fork", "pin", etc, and found similar-ish connectors but nothing I could use to search for replacements for the broken ones in my Hive unit.
Connectors on Hive backplate
For reference, the connectors make contact with pins in the main part of the Hive unit when it's mounted onto the backplate...
Connectors on main Hive unit
