I have a 1979 home; I'm looking to replace 2 light switches in my bedroom from toggle style to decora-style.
I would like to double-check some things before starting and any help is much appreciated as I'm a novice, but learning quickly.
There are pictures as well, but here is the wiring setup from what I can see:
2 single-pole toggle switches - the left controls the only light fixture, and the right switch simply controls an outlet.
There are 4 cables in the junction box, described below:
- Cable 1: 14/2 (left hole of the junction box)
- white is connected to wire nut #1 w/ white cap
- black is connected to wire nut #2 w/ red cap (nut is attached a) backstab of left side of right switch, and b) backstab of right side of left switch)
- ground is connected to wire nut #3 (and attached to both left and right switch ground terminals)
- Cable 2: 14/2 (also left hole of the junction box)
- white is backstabbed into left side of left switch
- Cable 3: 14/2: (middle hole of junction box)
- black is connected to wire nut #2 w/ red cap -ground is connected to wire nut #3
- Cable 4: 14/2 (right hole of junction box)
- black is backstabbed into right side of right switch
^ might not be 100% I have the above correct as there's lots of wires in the box, but Ive reviewed it several times as best I can.
(Side note: if there is a free modeling tool that lets me create a visual wiring diagram and that's easier than pictures or the above text descriptions, please let me know! )
My [novice] interpretation of this wiring setup is that the left switch, because it has 1 white and 1 black attached, could be a 'switch loop' . The right switch, because it has 2 blacks, one is hot coming in, and the other is a hot going out- probably to the outlet that it controls.
Arriving at my question, if you see the pictures below, am I correct to simply 'preserve' this setup by attaching the left switch's white and black wire into my new decora switch's 2 brass terminals, then attach the ground of course. If indeed it's a switch loop, maybe put black electric tape around the white wire to indicate its a 'hot' ? Finally, attach the 2 black wire's into the other new decora switch on the right, and ground? (power off 1st, ofc)
Thank you very much! 4 cables was a lot to interpret on my own :)
