My 7 year old LG washing machine seems to be tripping the breaker when turned off. Once the cycle is over, the machine turns off and then does not turn on again. I shut off the breaker 5 seconds, turn the breaker on and the machine turns on...
Also, I have tested this: machine stops working, I plug a lamp in the outlet and it works. Then I replug the machine and it works...
Any idea what is the reason for this?
